dvleemin
Jul 27, 2017Explorer
dvleemin wrote:1995brave wrote:
You may have lost the ground which looks to be labeled "TP" 14awg White wire going to the chassis connector on pin "E". Turn on all the lights and what is not working marker, brake , turn, etc. According to the drawings you have a ground block(all white wires) in the power cord compartment. Start there and look for a wire broken, chewed through, etc. Located in the body 12volt wiring diagram.
Thanks!
By power cord compartment do you mean where the shore power connection is? Or where all the chassis fuses are?
I'm assuming this is it:
38,768 PostsLatest Activity: Nov 21, 2015
