bshpilot wrote:
as PKennedy says - install a FUMOTO Valve on the drain pan (Ive had one on my f350 diesel for over 8 years now & love it)....then you can stop the flow anytime you want !
its a lot less messy too & you don't need to search for a wrench to pull the drain plug.
our MBE4000 / DD13 takes 42 quarts (10.5g)...i just drain it into some 5 gallon jugs & switch jugs when they get full.
these valves don't open by accident or bumping ! you can install an optional hose clip/ring (sold with the valve) to prevent tampering.
this thread seems to be dropping posts after these pictures were posted so this is a test to see if this post will post.
