Oasisbob's avatar
Oasisbob
BRAKE CONTROLLER PLUG LOCATION?
We bought a 2018 Ford Explorer with factory tow package. Has class 3 hitch and 7 and 4 pin plugs. I was told my Prodigy 2 brake controller would plug right into the system with the special adaptor cord which I bought. I have searched the web to find specific location of the plug. Based on the video's it is under the steering colum but not sure how to access it. Has anyone done this? I am stumped.
  • Need to lay on your back and start digging. My old F150 was under the dash between steering column and center console area.
  • enblethen wrote:
    This information is from installation instructions:
    The harness for the Ford Explorer/Mercury
    Mountaineer is located behind the vehicle glove
    box on the Passenger side or the harness will
    be located underneath and left of the steering
    column, taped to another harness near the
    emergency brake pedal. There will be a
    6-pin connector that mates with the one
    Might have well just said located somewhere under the entire dash, that is a lot of "real estate" to cover :E
  • This information is from installation instructions:
  • Typically the connector will be closer to right of the steering column over near the center stack where your radio/heat controls are. Look around that area under the dash, most likely will be very close to the place where the factory brake controller should be (factory controller is optional on F150 but there should be a dummy plastic cover in place where it should go if you had it from factory..
    Typically the connector may not be physically seen, may need to feel for it or remove the center stack assembly to make it easier to find. They are in a bear of a location.. At least that is the way it has been up to 2006 which was our last truck without factory TBC..
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 22, 2026
