StanleyandIris
May 16, 2012Explorer
Take a day to go look it over and test drive it. If you are mechanically inclined, great; if not, take a friend who is with you.
Test every system to make sure it works properly, inspect for damage/leaks/rust, etc.
Know ahead of time that you may need to put out an additional $3K for tires, depending on the age of the ones on the MH. Also know ahead of time, that like a 12 year old car, you will have issues along the way just because of the age of the unit and things like the water pump, fuel pump, fuel lines, etc., disintergrate with time. What may be fine today will fall apart tomorrow. It is the nature of the beast.
I recommend that you visit the website at PPL Motorhome in Houston, TX. It is a consignment dealer with a large selection of pre-owned units which you can 'see'. It will help you to get a good idea of what you can get on your budget and you may find that the Damon is the perfect match for you or that it isn't the best bang for your buck.
Iris
Iris
38,782 PostsLatest Activity: Sep 10, 2026
