overdrive75
May 19, 2020Explorer
^^ No drain plug, I gave up on that. All the ones that had drain plugs where those squared off ones, and after watching some of the Banks videos on diff covers squared off ones seems like a bad idea. Plus there may have been a clearance issue with the heat shield on the front of the gas tank. The nodular iron seems like a bad idea for heat dissipation. This is a Dana Spicer part fit on perfect, I used a gasket too instead of the RTV. The link is above in a post from where I purchased from.
38,709 PostsLatest Activity: Mar 12, 2025
