BordercollieExplorerMar 17, 2023Recommend Good E-450 Dash AC Repair, SoCalOur 2004 Fleetwood Tioga 26Q has a dash AC problem, the vacuum actuator is not working to divert cold air through the dashboard vents. This is caused by a leak in a vacuum hose that is located in the...Show More
30sweedsExplorerMar 22, 2023The "band-aid" fix I use is a permanent repair using all factory parts,replacing the failure prone poorly designed original setup.
Related ContentE-450 Stuck on Defrost ModeWater Heater Replacement RecommendationsE-450 Spare Tire carriersWind noise E-4502002 E-450 electrical schematic
