Ed_Gee
Nov 19, 2022Explorer II
Geez Why replace the alternator when the problem is with whatever charger/converter the RV uses to charge your battery when on shore power. Since you are still having the overcharge issue with a new battery I would think most likely the problem is with your shore powered charger unit. Find it, check it out and replace if necessary.
38,780 PostsLatest Activity: Nov 24, 2017
