I am having trouble getting over the air channels and I have the stander Rv antenna, is one antenna better then the other, just wondering if the new types of antenna are any better
Also check all your connections. I had the same problem and found a bad connection inside the ceiling, where you cranked up the antenna. They had used a coupler to connect from antenna to inside cable. The actual cable inside the coupler had broken off. Corrected this and received the channels I should have been receiving.
