KevinEExplorerFeb 24, 2016Slide AlignmentI have an 02 Holiday Rambler Endeavor. When it rains and the coach is tilted slightly the wrong way, I get a wet spot inside the lower front corner of the bedroom slide. Looking at it from the outsi...Show More
P3TCExplorerFeb 24, 2016If you have rollers on the bottom of the slide, see if the they can be adjusted to level the slide.My front slide has the same problem.
Related ContentAdding power outlets in slide with no wiringSlide alignment problem after awning hangsSchwintek slide top/bottom alignmentSlide accident - alignment issues.Alignment shop
