davehultin
Aug 16, 2023Explorer III
Rick Jay wrote:
If yours is wired similarly, it's possible the front two slides are on one control unit and the third slide is on a separate unit. Since your rear slide works, that controller is functional. ...
Here's more information that didn't make the original post (because my father-in-law decided to head home with us by that time): The rear slide stopped working too. Hmm. :h
But I think you're on to something. One of the last panels he opened revealed what I believe to be the control units you mentioned. I noticed them and thought I'd give each one a solid push to make sure it was seated properly. When I did, I heard a gentle "crackling" sound. I never once thought anything was breaking, but I thought that perhaps it was the sound of something loose (like several pins that I didn't see) clicking into place. I don't remember if that was before or after the back slide stopped working.
Another thing that happened (before the back slide stopped working, I think) is that my father-in-law pulled out the tray with all the batteries to check connections there, and one of the wires simply fell apart when it was moved, looking as if a knife sliced all the way through it. (Battery acid burned through it, I suspect?) We fixed that with some crimp connectors, but that didn't seem to change anything. By that time, we didn't test things as completely as we normally would have, because there were two wives that were approaching the end of their "patience allotment".
As it stands now, the mobile tech is scheduled to arrive on Monday. I bet he'll find it has something to do with those control units you mentioned.
38,706 PostsLatest Activity: Jan 31, 2025
