ncrowley
Mar 12, 2023Explorer II
Determine the weight you can pull by using the following calculation:
GCWR - GVWR
For these smaller RVs, you can assume you will be close to your GVWR. Do not be fooled by the hitch rating, which is 5000 pounds. That is more than the Sprinters can pull.
Use the Winnebago View as an example. All of the models have a GCWR if 15250 pounds and a GWVR of 11030 pounds. The difference is 4220. Therefore, the most you can pull is 4220.
Personally, I would not want to pull right at the max. My Jeep weighs 4400 pounds and therefore cannot be pulled with any of the View models. These numbers are about the same for all of the Sprinter chassis models I have seen.
GCWR - GVWR
38,709 PostsLatest Activity: Mar 12, 2025
