EMD360's avatar
EMD360
Re-stringing the day/night shade
I bought a kit at Camping World today to restring the shade I had "fixed" last summer. I just shortened the cord to bypass a broken area, but it broke in a different place last trip so I bought the new string and springs etc.
I followed the instructions on the internet including a set from Winnebago. But I think I may have gotten something wrong. I never read that the shade required one longer and one shorter string and I can't see why it would. Also when I pull on the string on one side, the other side gets shorter and that shouldn't happen looking at the drawing. At least I don't think so.
I used two strings of the same size from the kit, and doubled them to loop through each side of the spring. I restrung as directed with the outer strings crossing over and threading through the inner day shade holes and the inner strings crossing over and threading through the outer holes, and after reassembling the day shade to the night shade and putting the pull bar back on, I tried to even up the cords to tie them. The result is that one string is definitely shorter than the other one by several feet. AND pulling on one side shortens it on the other. Why?
I have not rehung the blind yet but I hope the shorter string will be long enough to do the job. I wonder if I got the strings "crossed" somehow inside? Maybe when I was putting on the bottom pull--I had all the strings to one side until I slid it mostly across. Maybe I pulled out the wrong two strings at the bottom. But still can't see why four separate strings should somehow connect at the bottom??? Maybe at the spring, the string is slipping through the loop?
Magic.
  • Tie the strings to the spring. Do not loop them through the spring. You should have 4 separate strings. 2 on each side of the spring. Center the spring in the top "rail" then follow stringing diagram.
    You could loop them through the spring but tie them so they do not slip. They need to be fixed to the spring.
