Seeking advice concerning the best tire pressures for my motorhome. I have a 2004 Winnebago Journey that is built on an oversized Freightliner chassis. The chassis GVWR is 27,900# and my coach weigh...
Thanks for the input. This will give me some peace of mind when I reduce my tire pressures. I did weigh the axles using a CAT scale and will try to find a place to weigh all four corners. Until then, I will run my tire pressures 10 psi above the Goodyear minimum for each axle. This will be a 15 or 20 psi reduction from current pressures and should give me a much softer ride.
Does anybody know how the reduced pressure will effect my corner handling and straight line tracking?
