jtfcons
Sep 22, 2017Explorer
A 150 psi compressor means that it shuts off at 150 psi, and turns on at some other pressure (???). Don't know what your unit does in this case but if it is below 130 psi you will have a problem filling a 130 psi tire because when getting at or near this level the air flow will stop or severely slow down. If this is the case you will have to force the compressor to turn on by using a hand nozzle to get it to turn on and begin filling to the 150 psi shut off point. You can fill the tire in this cycle. Hope that makes sense.
38,763 PostsLatest Activity: Dec 26, 2025
