Artum_Snowbird
Nov 20, 2017Explorer
Re: winnebago 2002 adventurer (30y)
Best thing to do might be to take a set of jumper cables off the battery bank and hook them to two wires that you can screw under the converter terminals. Do the negative first and see if they are now charging, then try the positive on it's own. Your wiring might be faulty, or it just might be loose connections.
