blawless
Jun 14, 2022Explorer
For those who couldn't follow the link I sent, here is a cut and paste version.
Coachmen Aurora (02-05) W/Wiper Repair Parts List.
For anyone who has windshield wiper motor/assembly issues. My wipers stopped working on our rush home last March to get back across the Canadian border before the shutdown. My wiper motor over heated, and the wipers stopped or vice versa. Just before arriving home the signal lights quit as well. After a long knuckle busting search for the cause I finally got to the root of the problem.
The root cause was a badly corroded wiper pivot shaft on the drivers side that seized causing the motor to overheat which in turn melted the wiper circuit control module mounted on the floor behind the brake pedal. The wiper fuse should have blown first but Coachmen used a 30 amp fuse in that slot instead of a 15 amp. Bad set up as the control module will melt before the fuse ever blows. It took a few weeks to determine all the parts numbers as Coachmen now Forest River have nothing on file as to what after market system was used.
Here's the part list:
1. Wexco pivot shaft assembly #300657
2. Pantograph adapter dry #200241
3. Dayna pantograph wiper arm wet #200487N
4. Wexco Wiper motor #D103
5. Dorman wiper control module #906-151 (906151) pulse module. (This module controls everything attached to the wiper arm on the steering column, wipers, signals, W/washer pump and bright lights)
Replaces a number of Ford part numbers no longer available.
(ie) YC2Z17C476aa
One other major issue..!!! These parts are not available or listed by our Canadian auto parts stores. So I had to order them from the States. With the exchange rate at $0.74 on the dollar it cost me an additional $300 plus shipping and brokerage fees. But hey... I now have working w/wipers just in time to park the MH for the winter till the border opens again.
I hope these part numbers will help someone else out and save weeks of online searching.
Happy Trails.
(ie) YC2Z17C476aa
Happy Trails.
38,709 PostsLatest Activity: Mar 12, 2025
