crasster
Feb 28, 2017Explorer II
Re: wipers stopped working - again
Put the meter on 20V DC. Go to the motor and unplug the positive wire. Then put the meter on the positive wire (the red wire from the meter) and put the negative wire either to ground (any frame metal on your unit) OR on the negative wire going to the motor. Be sure to have somebody turn on the wipers. You should see power of around 12-14Volts.
