Executive45
Dec 02, 2014Explorer III
The toad's brake lights operate in conjunction with the brake lights on the coach...if you use the toad's lighting system, diodes are necessary to prevent backfeeding into the toad's electrical system. To avoid this, you can add separate light bulbs in the toad's tail light housings and make the system independent....easily done either way and can be done in less than an hour with common tools....Dennis
