nehuge's avatar
nehuge
Rear end noise, anybody know what this is?
While going down the road, anywhere from 40 to 70 mph there is a loud humming noise from above the rear axle. It sounds as if I have an F150 with humongous monster mud tires on it. It's that same sound when you hear one of those big knobby tire guys going down the freeway.
Any ideas? If I let off the gas it quiets down, but holding it at speed or accelerating is when it does it.
I thought tires, but then though my other Class A with dually tires on the back didn't make that noise. Tires are brand new, and it did this sound before and after new tires anyway.
It's a Ford F53 Chassis, 1995, 35 footer. I have not checked differential fluid yet.
    It sounds to me like your ring, and pinion are worn on the "drive" side, as it stops when you let off. And as long as it is pulling or holding speed it roars. In other words, when the "drive" side is working. It makes noise.
    Easy fix really. New ring, and pinion. Less expensive than you think
  • record the sound and send us a wave file.
    nehuge wrote:
    While going down the road, anywhere from 4to 70 mph there is a loud humming noise from above the rear axle. It sounds as if I have an F150 with humongous monster mud tires on it. It's that same sound when you hear one of those big knobby tire guys going down the freeway.
  • the pinion shaft bearings maybe. If you ran it to long with no oil it wont go away when you fill it.
  • you need to put a bearing kit in your rear-end.you either got a bad/pitted bearing or a burn race.did the rear end get hot or water in it
