Roadglider09ExplorerAug 27, 2013Rear Tire Pressure's - Please check my figuresJust had the 4 corners of my 2012 Georgetown F53 chassis weighed. The left side dual is 6,700 lbs, the right side 7,100 lbs. I would take the heavier of the 2, 7,100 lbs, divide by 2 (3,550 lbs) then ...Show More
IvylogExplorer IIIAug 27, 2013Sounds correct assuming you used the D "dual", not S "single" part of the table. Agree with previous post about adding 5 extra psi.
Related ContentFiguring MileagesFiguring the correct tire pressurePlease helpTire pressuresTire Pressure?
