Williamh's avatar
Williamh
recall on Norcold refrigerator
As many of our forum members know, there has been a recall on a part of the Norcold refrigerator. I have had four replacements and now waiting on the part for the fifth time. I am wondering if other members are having the same problems so many times as I have had. Does any of the forum members have any remedy for the replacement part. Is there anything that I may be doing or anything that I can do to keep from this part going bad so often. I had this part replaced in Sept. 2014, went to Fl. for the winter and came back home the first week of March 2015. Everything worked perfectly. I parked it under my shed and did not use it for about 2 months. When I was getting ready to take a trip yesterday, the refrig. would not come on. When this replacement part goes bad, the little red light blinks and nothing works. Will not switch on or anything. If anybody has a solution, I would sure appreciate the info. I don't know the name of the replacement part, but its on the back side of the refrig and on the outside. Thanks in advance
William
  • I just looked at Norcold site. Here is the info on model numbers:
    Identify and write down the refrigerator model. If it is a Norcold 1200, 1201, 1210 and 1211 model, go to step 2.
    step 2.
    Identify and write down the refrigerator serial number. If the serial number falls in the range of 315525 and 13088811, go to step 3.
    step 3.
    Identify and write down the cooling unit serial number. If the serial number falls in the range of 700000 and 13085759, go to step 4.
    step 4.
    Call your dealer immediately.
    I just check mine and I am a model 641
  • I believe the model no. for the norcold ref. is the 1200. I may be wrong on that, but I am sure someone on the forum knows better than I dol
    William
  • Wouldn't it be nice if norcold fixed the problem instead of adding junk.'
  • We went through 4 mod upgrades as well It was a real pain. But when our fridge went up in smoke it probably saved the day though. There was a fair amount of charcoaled wood behind the fridge when we eventually ended up tossing it out and putting in a residential. I suspect without the mod it would have been a fire. Definetly worth having.
  • Which Norcold refridgerator? Or is this for all of them.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Search "ARP" on here and forget NoCold and rev F bandaid. Six tries to get something that shuts the power off when there is not a problem :S
  • It is a 'electronic high-high temp sensing' safety device that cuts all DC power to fridge.
    They (Norcold) or now up to REV F..........which should tell you that you are NOT the only one that has had failures of device.
    Failure rate is high enough to question what good is device?
    Dometic has a 'recall' device also.........no electronics used.
    Just simple rewiring scheme incorporating an addition high temp sensing thermodisc which cuts all dc power if it trips. VERY low failure.
    Norcold 'recall control box' can be reset using a strong magnet.
    Lay magnet on face of box and move it make/forth side to side top area until you hear 'click' and RED light goes out.........PROVIDED that is hasn't really cut off power due to high-high temp (ammonia smell/yellow residue around burner area, 'no-co' faults etc.
