AllegroD
Oct 05, 2015Nomad
As stated, gravel is fine if thick enough, packed well and usually with a binding to prevent separating and sinking.
As to jack maintenance, WD-40 application is not the best idea, unless you follow the Mfgr guidance.
For HWH levelers, see their service/maintenance website. HWH Service Bulletins.
ml47149
ml47149
ml47149 wrote:
If the jack is extended, use soap and water or WD-40 on the jack rod then wipe the rod dry with a clean cloth.
