turbojimmy
Apr 21, 2015Explorer
Bank one is the left side on a 6.0L Chevy. It refers to the side the #1 cylinder is on; bank 2 is the other side) and sensor one is the pre-cat sensor (sensor 2 refers to the post-cat sensor).
I would think you'd be able to see it somehow rather than feel around for it. You're also going to have to follow the wires (probably not very far) to a plug so you can disconnect it.
EDIT: And a 7/8" open-end/box wrench will come in really handy here. If you're lucky enough to be able to get a socket on it you can buy an O2 sensor socket that has a slit in it to accommodate the wires.
