j-d
Apr 22, 2015Explorer II
Bear in mind, it's "probably" the O2 sensor. Commonly replaced, consumable kind of part. Same idea as a spark plug. Still, other problems in a system "can" trigger a code so simply replacing the part bearing the code's name may not clear the problem. I tried to look your 6.0L up without Year or VIN, but he chart I found points only to the generic codes and 0053 is the "heater" portion of the O2 Sensor.
