wa8yxm
Nov 21, 2014Explorer III
Well the battery is good or it would not be running on propane.
If this is a Dometic then in the outside compartment on the "Floor" is a terminal board with fuses, Check the fuses. To the left of that is a black box with more fuses, Check those, and all connections.
Also make sure power is getting to the terminal board.
And if all else fails, New black box is indicated (the main control board).
38,769 PostsLatest Activity: Apr 03, 2026
