Effy
Nov 21, 2016Explorer II
roscofrmh wrote:toedtoes wrote:
I believe nowadays most RV fridges are 2-way. That means they only run off propane or electrical. If you are shutting off the propane when you drive, then the fridge has nothing to run on.
Thank you for your responses. Yes, I was told not to leave the gas on while driving, so if it is a two way frige, it only makes sense it won't cool while going down the road. I will follow up with a dealer when I can and confirm this.
Well there ya go. No LP, no fridge - unless of course you run your genset. Who told you not to leave LP on when driving? Then you have no heat and you found out, no fridge either. If you are set on leaving LP off while driving, then run your generator to power the fridge, but as I stated, most of us leave the LP on. The systems are designed to operate while driving.
38,778 PostsLatest Activity: Jun 10, 2026
