usersmanual
Nov 21, 2016Explorer
roscofrmh wrote:toedtoes wrote:
I believe nowadays most RV fridges are 2-way. That means they only run off propane or electrical. If you are shutting off the propane when you drive, then the fridge has nothing to run on.
Thank you for your responses. Yes, I was told not to leave the gas on while driving, so if it is a two way frige, it only makes sense it won't cool while going down the road. I will follow up with a dealer when I can and confirm this.
If you had a decent sized inverter and had fridge plugged into it then it will cool while driving but as u have learned best to just use LPG for fridge while driving
38,778 PostsLatest Activity: Jun 10, 2026
