Bruce Brown wrote:
gfs1943 wrote:
dougrainer wrote:
I would suspect the rear cooling fans have a problem. They were NOT working and then they started to work. Possible BAD Tstat for cooling fans. Doug
I'm happy to see you responded, Doug. I appreciate your expert advice.
Where would I find the rear cooling fans and the Tstat? I cannot see or hear the fans.
NOTE: This fridge is NOT in a slideout, if that makes any difference.
I appreciate your help.
The cooling fans will be on the back of the fridge. Take to outside cover off and look up. There should be 2 pancake type fans mounted on the tubes.
Not visible. If they are there, they must not be working because I can't hear any fan noise. Any chance they are in the top of the vent column?
