- j-dExplorer IISome coaches have a void under the fridge. A fellow camper found his shutoff down there, under the fridge. This was on a Holiday Rambler. I don't know what he had to do to get in there.
- 4x4vanExplorer IIICompletely different model, but my 2004 Itasca M30W (class A) has the fridge on the passenger side, but the water valve for the ice maker is on the driver side, under the counter near the kitchen faucet. Just so that you're aware it could be nowhere near the actual fridge. Contact Four Winds; they should be able to tell you where it is.
- lj2654ExplorerIf there is a shutoff it usually is in the outside access panel. Follow the small tube that supplies the icemaker water and you should see one. If not there then near the ice maker filter if you have one on your coach.
38,769 PostsLatest Activity: Apr 04, 2026
