dougrainer
Jul 07, 2014Nomad
crasster wrote:
Hmm, I wonder if the upper vent could be causing this on electric. I take it that the vent is on the roof? May be clooged with bugs/hornets nest, etc.
Something is causing that thermo to pop.
If you have a BAD cooling unit, the Thermo will "pop"
If you have blocked ventilation (your roof vent) the Thermo will pop
If the Thermo is BAD, it will pop
When the Thermo pops and continues to pop, the ONLY thing a novice can do is check that roof vent for obstructions. IF NO problems there, you need to get it in to a qualified Refer tech to find out if the CU is bad or the Thermo disc is bad. Doug
