TNGW1500SE wrote:
It's been level for 24 hours and turned on
The green light is on
It's a model # N611
It's not cooling at all.
The interior light comes on when you open the door.
The Gas lights when I switch it over to gas
Has 110 volts at the plug
the bottom pipe where it goes into the burner is "warm" (could be called "hot")
The flue is "good and hot" so it's heating
When I switch to gas the yellow gas light comes on and does not flash
BUT it will not cool down inside at all.
Anything I could try?
I have a multimeter here.
Your cooling tower has either sprung a leak, or, your heating element is bad on 110AC. One or the other. Take it to an RV Dometic/Norcold refrigerator repair shop to troubleshoot the exact problem(s) and fix. They'll be able to give you a cost estimate too.
