tropical36
May 28, 2016Explorer II
Vt Rv wrote:
We're just getting ready to leave on a three week trip and I started the refrigerator only to find it isn't working.
It's a Dometic RM2852, the control panel lights up and the vent stack gets hot so I know the LP is working. Also there is plenty of LP in the tank. The inside of the refrigerator gets warm instead of cold and there is an ammonia smell when I open the freezer door. I also have it plugged in so it should work on AC but seem to go right to LP.
I checked the vent and there is a yellow powder around the base of it.
I'm guessing I need to replace either the cooling unit or the whole thing. The problem is, as I stated, we're leaving this afternoon for the first leg of the trip taking us to Fort Myers, Florida from Vermont.
I'm looking for any suggestions or advise on either how to get it working or the best options for replacing it while on the road. Also should I be looking for an exact replacement or other models that will fit in the hole?
Thanks in advance for the advise.
I would probably just head for Ft Myers and then get the thing removed and get a residential replacement installed. Wouldn't have to fit perfectly and would get a smaller one that didn't require any cutting. You can always fill in the space later and my idea is for a slide out pantry if and when ever needing a replacement.
Depending on where you're staying, you should be able to do it yourself or get a tech to come out to your campground. Don't know your setup, but with whatever it might be, it won't take much for getting the fridge on an inverter circuit, as well.
