Good morning to all. Does anyone know how to disconnect the tubing in the back of the refrigerator. The tubing going to my ice maker has cracked and is spraying water everywhere. Thanks
Mine is accessible from the outside. Just remove the outside frig cover and the solenoid and water line are there. The actual valve to cut the supply off is behind the furnace intake on the inside. Just remove the screws and pull the louvers out and there is the water make up valve. I just put all new in mine.
