Whiskey_River's avatar
Nov 17, 2014
Refrigerator Condensation Drain Tube
Has anyone replaced the drain tube that runs from the drip pan under the finned plate of the fridge?
I have a Dometic RM1350 double door fridge in a slideout and the drain tube exits the back of the fridge between the 2 vents. "No access & can't reach down the top vent".
The drain tube was cheap plastic & the heat made the plastic brittle. It broke off where it exits the back of the fridge.
I think to replace it, you need to pull out the fridge(last resort), or try & run a smaller tube thru the existing hole & clamp it to the drip pan in the fridge.
Has anyone fixed this or have any ideas?????
  • Would removing the 2" square trough that the tube attaches to easier than removing the refrig from the place it lives? I just don't want to break it so if anyone knows how to take that out would you please post how?
  • Mine was also in the slide. I was able to change the hose without pulling the refrigerator. It took two of us one reaching from above and one from below. I used 1/2 inch clear tubing from Lowes. I won't say it was easy but we did it in about 20 minutes and it wasn't in a garage.
  • When I replaced mine, I could not quite get my hand into the spot to pull the old tube off the exit nipple, so I had to slide mine out about 6 inches - remove 4 screws on indoor mounting flange, disconnect gas line and 2 mounting screws outdoors, push the fridge about 6 inches.
  • Watched the 2 Ford videos on condensation drain tubing.
    Nice lady explaining and showing the fix. She said the fix is real simple & I agree if you are working on the fridge in the garage standing beside the back of the unit as she is.
    It appears the correct way is to pull out the fridge, but I am going to make my first attempt by cheating that some way.
    It does appear Dometic supplies the refrigerator with a 27 cent piece of plastic tubing that will fail in 2 or 3 years and no easy way to replace it.
  • When mine did that, I went to the local hardware store. Bought a brass union and a couple feet of clear plastic tubing. Cut the old tube inside the compartment, worked the union in, then attached enough clear tube to other side of the union to stick out the vent.
  • Simple very low cost repair
    http://rvrefrigeration.com/training-videos/
    Check out the condensation drain tube videos
  • I remember reading a thread about this, a year or so ago. You may find it, doing a search.
    It seems most said you have to pull the fridge out, but also a few had an idea to cheat.
    Good luck,
    Jerry
  • I watched a video on the computer the other day, will try and find it. Made by an RV dealers wife and I think the dealer was Ford RV.
    Found it, Fords RV Service and training. Type it in on the top bar and it should bring it up.
