fowlthing's avatar
fowlthing
Condensation pan is not draining?
Have 2019 Solitude 375res It appears the drain hose from the refrigerator condensation pan is clogged. I have blown on the drain and put a wire down it to attempt unclogging.
By chance is there a valve that needs opened under the camper?
Any suggestions or advice is welcome.
Thanks
  • There are cheap little plugs that you can put in the end of the hose to prevent insects from using it. Any rv parts dealer will have them.
  • I'm guessing clogged from mud dauber? I've had that happen in the past with several things. I'm just south of you south east Lowell.
  • Found the issue...removed outside cover and the hose was clogged there...posted before I had investigated enough...
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
