Good morning to all. Does anyone know how to disconnect the tubing in the back of the refrigerator. The tubing going to my ice maker has cracked and is spraying water everywhere. Thanks
If you look at the outside of your rig and find 2 vented doors where the fridge is you can likely make the repair. If there is only 1 door you must pull the fridge to the inside of the rig to access the line. It's time consuming but not overwhelming pm and I can walk you through it. Loving the rv thing. Jw
