hotbyte wrote:
When working correctly, you can usually hear them "click" as the contacts close - especially if you place end of a small stick to the relay, wrap your hand around the the other end and lay ear right up the end of stick in your hand. The stick will work like a stethoscope helping you hear noise internal to the relay.
If relay is disconnected and out of rig, a voltmeter can be used to check for continuity across the "power" side when 12V is applied to the "switch" side of relay.
Excellent input .... gives me much more visibilty on how the relays interface with electrical functions. Thanks!!
