Sez_Hoo_
Jul 27, 2013Explorer
Remote fuel filters
I have a Cummins CTA 8.3 ltr engine in my coach. My fuel water separator is located in the rear compartment with very easy access and serviceability. My fuel filter is mounted on the engine along with the fuel priming pump. The fuel filter is a bear to access and replace. And God help you if you have to use the priming pump. Does anyone know if Cummins has a remote fuel filter system that can be installed in the same compartment as my fuel water separator. I've seen coaches with Cat engines that have a remote system that has both filters and a fuel priming pump. Oh how I wish I had that setup.
