cgmartine wrote:
Ok. Further on my decal quest. Tried it again today, Monday. I placed the heat gun (hair drier) closer to the fiberglass, about 3 inches away, but moved it continually. I think the hair drier is probably best than an industrial type heat gun, which might produce too much heat. The first time I tried it last week, I was afraid to get it any closer than 5 to 6 inches. This time I tried it in combination with the putty knife, but it is hard, and extremely slow. I then tried the hair drier, followed immediately by the eraser wheel, and made faster progress because the decal was soft and pliable. The wheel did not need as much pressure and it was faster going. I was able to do about a six square inch area in about 20 minutes. This method is easier. As far as doing the edges, it can be done, but no heat should be applied, and if done with the eraser wheel, very little pressure should be applied, otherwise, it will lift up pieces of decal. One edge of the eraser wheel should be on top of the decal, and the other edge of the wheel over the edge of the decal, following the outline of the decal. If the entire surface of the eraser wheel comes into contact with the edge of the decal, it will begin to lift it up. Pheew.....I was a novice yesterday, and today, I am an expert!
I suggested earlier to use the hair drier...but also have it in the sun. I did this, and my decals came off rather easily.
