alkillion
Sep 30, 2014Explorer
Not a microwave, but I had a coffee maker that was mounted from above, except I could not find the bolts. Turns out the cabinet was engineered with a false bottom inside the cabinet. Slipped a knife in the crack between the inner bottom and the sidewall, lifted out the inner bottom, and there were the bolt heads. Removed the bolts, dropped the inner bottom back in, and all done.
Maybe yours has a false bottom too?
Good luck!
Good luck!
