MrWizard
Jun 10, 2018Moderator
30 amp shore cord and breaker panel
One each hot, neutral, ground 10 gauge wire
Generator possible wiring, very common
One neutral, one ground , two hots
One hot goes to ts stitch and breaker panel for 30 amps
Second hot goes only goes only too the second a/c
50 amp shore power
One neutral, one ground, two hots, all wires are 6 gauge
It is 50 amps on each hot, 100 amps total
This has nothing to do with removing the generator
You can Not just remove generator and splice wires to new shore cord
You need new breaker panel, new wire from panel to the New TS, all the way to the New shore connection
50 amp shore power
38,782 PostsLatest Activity: Sep 10, 2026
