Mile_High
Jun 11, 2018Explorer
DrewE wrote:OK, that makes sense I guess. I did have a 30A Montana with a 2nd AC option and it came with a 50A plug that fed the second circuit for the AC, but he rig was still 30A. It was 2003 so must have been the same approach. I did only have the 5500 gen. I guess I figured 7K was overkill, but as Dutch said, sounds like it was an option.Mile High wrote:
Something must not be factory - a 7K genset in a 30A rig? That is one waste of a generator.
It's a 7K generator because it powers the 30A supply plus an additional (separate) second air conditioner circuit. The motorhome is set up to only use one air conditioner on shore power, but can use both simultaneously with the generator running. This is (or at least was) not all that unusual of a setup, though it does have its obvious inconveniences and drawbacks.
So I do remember looking into making that Montana a true 50A, but it would have taken a new panel and pulling in some new circuits and after a while I figured it wasn't worth it and eventually traded. It may be worth it for a MH. The biggest thing to overcome is trying to get in some additional outlets to share the panel and that didn't look easy.
38,782 PostsLatest Activity: Sep 10, 2026
