Ivylog
Apr 29, 2017Explorer III
Go to EBay and look at pictures of 1200 cooling units and then ones for smaller sizes. You will see very little difference in the size/amount of the coils. Now look at a Armish 1200 cooling unit... almost twice the the size in the lower section.
When you undersize the cooling unit it has to run longer/hotter and air movement fans are needed. Put it in a slide where you do not have thermal syphonIng of the air or there is too big of a gap at the back of the coils and you do not get enough air flow over the coils... poor cooling.
*Why does a NoCold 12xx have to have a thermal shutdown added to it? They could not even get this bandaid right as it is on at least revision E and it still shuts it down when nothing is wrong... especially if you get the black box moist. Fortunately D and E can be reset using a magnet.
38,777 PostsLatest Activity: May 19, 2026
