msmith1199
Sep 08, 2013Explorer II
Removing the old TV (With photos) Tropical by National RV
Okay, some of you guys lied to me! I'm going on about 2 hours now and still don't have this TV out! But I do have a new found respect for National RV. I was always worried about this giant TV over my head and every time I hit a big bump I was worried it was going to come crashing down on my head. Now that I see what's holding it up there, there is no way a bump was going to bring it down. I had read the other stories about removing the frame and straps holding the TV down. Not on mine. This thing is bolted into a complete steel box. And I mean solid steel on both sides and the bottom. I haven't seen the top completely yet, but it looks like it's lag bolted at the top into the steel frame of the motorhome.
I'll post some photos when I get done with this but I'm having a heck of a time getting it out. The steel box the TV is in looks like it was designed around this TV. It fits snuggly in the box and then there was a piece of angled steel across the bottom that held the TV into the box. I figured once I removed that the TV would slide out. Well once that piece was moved I can tell the TV is loose in there, but it won't slide out because the TV extends up into the ceiling. The bottom of the steel box is held on with six bolts. I'm trying to get those out now without having to disassemble the entire front section. So I can just barely get back in there to reach the bolts and turn them a little at a time. I'm down to one bolt left in the far back and needed a break. I have screw drivers stuck in four of the other holes because once I remove this last bolt I think the TV will be free to drop straight down. Hopefully the screw drivers will hold it until my helper gets home from shopping and between the two of us I can hold it while she takes out the screw drivers, and we lower it to the floor.
