Don_Parrish's avatar
Don_Parrish
Removing US Gear D-Celerator From Toad
US Gear installed in Jeep Unlimited in '08. Removing the mechanical was simple and for that matter most of the wiring. There are five wires which come through the firewall and I'm apprehensive about just cutting those. I have no installation information and can find none on line. Did not install myself 10 years ago. The five wires are Red (larger gage-power I'm sure), Black (ground?), Blue (control?), Yellow (control?), and violet (connected with red wire plugged into the control module). Yet to disconnect and remove air/vacuum device under the hood. Maybe as simple has remove all the wires and plug the "t in" of the original configuration?
Do we have a US Gear expert? I'm sure we do. Help would be appreciated. Test drive so far proves I haven't screwed up yet.
Don Parrish
1 Reply
  • I have the complete US Gear installation procedures including a video. Should help you just work in reverse to remove it. Send me a PM and I’ll be happy to share it with you.
