Replies have been turned off for this discussion
- rgatijnet1Explorer IIIDenatured alcohol will remove the wax as well as any contaminants that have accumulated on the surface.
- BrianinMichiganExplorerOxy Clean
- Tom_BarbExplorer IIAny good cleaner wax will do both jobs with one application.
wax on, wax off, :) - wny_pat1Explorer II
hershey wrote:
I'm with hershey and Born to Travel on the Dawn Dishwater Detergent! Zanio, a high end show car polish requires that the wax be removed before Zaino is applied. They say "wash your vehicle thoroughly with Dawn (or comparable) dish soap to remove any wax, grease, and oil from your paint".
Suggest you use Dawn Dishwater Detergent.
Another product is called TCP or TSP I think....somebody correct me here. - Born_To_TravelExplorerX2 On the Dawn Dish Soap.
- donn0128Explorer IIWash it with laundry soap and warm water, i assume your going to rewax it? If so, use some polishing compound, not rubbing compound. Followed by lots of good quality wax. An electric buffer is handy to do the job quickly.
- Passin_ThruExplorerYou can use any RV and Marine polish wax which removes the old wax. CW carrries it and it will take about 1 gal per 30 ft of side. This stuff is High $ but will work on a small area.
http://www.autobodytoolmart.com/detro-clean-wax-grease-remover-1040-p-14262.aspx?s_kwcid=TC-3384-5006716648-bb-172163418 - hersheyExplorerSuggest you use Dawn Dishwater Detergent.
38,782 PostsLatest Activity: Sep 10, 2026
