I did all my a few years back. To figure out the space size just scrape or cut the window glaze back. I use the one that slides. Once you get a small area clean you can measure the space between the panes. Back then a 66 foot roll cost around $60 and the sealant that seals the spacer was right at $10 per windows. Takes just about one tube per window. I have 8 windows so had two rolls of spacer with a lot left over and one tube of sealant per window. The first one took a day to take out clean and repair and put back in. After that two per day easy. Cheaper that the several hundreds per window. Pm me if you need any more info.
