colonelcorto
May 28, 2018Explorer
Replace old Onan 5000 with box store portable
I have a 1996 Fleetwood Southwind with a non-functioning Onan 5000. It has a fuses B winding, and a burnt up voltage regulator. I know this because, luckily, Inlive with 5 miles of an Cummins/Onan dealer/service center. For $120 they were able to tell me that the cost to repair is estimated at $1,800. I can afford to burn up a cheap off-brand portable every couple of years for that price. Let me be clear, I am not interested in spending the $1,800 to repair a 23 year old generator. A newer Onan 5500 is $4,000 installed; also out of the question.
My unit has 30 amp service and two roof mount AC units. I believe one is a 12.5k btu and the other is a 15k btu unit. The dead Onan was a single phase 120 volt system that was rated for 41.5 amps. There are two separate input lines running to the transfer switch: a 20 amp and a 30 amp line. I know this because the circuit breakers on the side of the dead Onan were labeled as such. I am almost certain the 30 amp ran the entire motorhome except the rear AC unit (12.5k) which is ran by the remaining 20 amp circuit.
I am aware that My motorhome cannot use the 30 amp 240 volt plug that is in most portable generators, it’s 120volts only. However, can I spit 240 volts into 2x 12 volts and energize those two input lines that run to the transfer switch? Each line would see 120 volts, right? There would be no danger of 240 showing up anywhere, right?
I would like to be able to use my motorhome in the hot summer months and do the occasional boondocking. This requires a functional generator. I would also like to not set myself or my family on fire.
Thanks!
Thanks!
