stlucia0127's avatar
stlucia0127
Replace Use/Store Switch
I own a 2015 Thor Hurricane 32N (class A).
The "Use/Store" switch needs to be replaced and it is located at the entrance to the coach (near the door). It doesn't have a part number but has six leads to wires in the back. Does anyone know where I can get this part?
Thanks!!
  • My “relay” has two 5amp fuses. One on each control wire. I pop one every year.
    I was told the problem was the switch, wink, wink. Had the switch replaced. I now have a box of 5amp fuses. Much simpler to change a fuse.
  • fivejackie wrote:
    Mandalay Parr wrote:
    Are you really sure the switch is bad?
    It could be the relay. Make sure you check the relay and the switch.
    Yup, the relays go bad much more often than the switches do.
  • DrewE's avatar
    DrewE
    Explorer III
    It would almost certainly be a DPDT center off momentary switch. Assuming it's of a somewhat standard size and style, you should be able to order a replacement switch from a decent electronic components supply company. Mouser and Digi-Key both have extensive catalogs and will do small orders, though for a single switch the shipping and handling will probably exceed the part cost.
  • Have you tried calling the parts department at THOR in Elkhart?? On that late of a model, they are probably in stock.
