Old-Biscuit
Nov 27, 2015Explorer III
John&Joey wrote:zach477 wrote:
Even with a full grey tank, the AAV shoukd still be doing its job, right? What gives?
I have a 5'ver that when the tanks become filled there is an overflow pipe. Prior to it hitting the ground, it sits on top of the tank (I think.) Don't smell so good.
Waste tanks do not have overflows.......EPA Hazard :B
But the drain pipe and vent pipe going into top could be installed using a grommet vs being hard glued.
With an overfull tank the grommet can leak
OP.......
Did you use one of the inexpensive (cheap) AAVs ? $3-$5
That just have a flapper pulled close by a rubber tang
Studor makes a better one and more expensive $20+
38,782 PostsLatest Activity: Sep 10, 2026
